grimprime221
Re: Will not start
Tested the tps using the gray and blue spots and the meter showed about 6 to start and when I moved the arm down the meter showed it down to about 1. which after searching sounds about right.
Still not showing any codes, Tach doesn't jump too much and have egr deleted.
This is important because if the ECM sees more 2.5 volts it goes into flood mode and won't fire the injs. I suggest you check that just to rule it out if nothing else.
