skwayb
NWSTP
Re: Tuner pro 5 tracer cell on table screen & TP5RT questions.
I would suggest reading the P4 Document in the FAQ section of Code 59. It describes how everything works. I put all the variable names in the XDF so you can see what they do when you read the P4 document. (i.e F1 table, KCTBIAS - Coolant bias, etc.)
http://www.code59.org/index.php?option=com_fireboard&Itemid=38&func=view&catid=22&id=7986
For Spark read page 76. This tells how it is calculated
Spark timing advance calculations are the sum of the following term:
· Main Spark Advance Table (*F1*)
· Coolant Temperature Correction Table (*F2)
· EGR Correction Table (*F4*)
· Power Enrichment Spark Advance
· Spark Advance Boost Table (*F3*)
· Minus the Following Bias Values:
1. Coolant Advance Bias (*KCTBIAS*)
2. Manifold Air Temperature Bias (*KMATBIAS*)
3. Boost Advance Bias (*KBSTBIAS*)
4. Spark Advance Run Time-out
5. EGR Advance Bias (*KEGRBIAS*)
6. Malfunction 32 Test term (*KKEGRSPK*), if applicable.
System spark advance is calculated relative to top dead center (TDC) but must be output relative to the HEI reference signal. The difference between TDC and the reference signal is accounted for by subtracting the value *KREFANGL* is the same as the static advance angle.
Output Spark Advance (w.r.t. TDC) = System Spark Advance - *KREFANGL*
