Mild bowtie build
MikeRenz
not stock
Re: Mild bowtie build
:tup: i think thats the FIRST intake to be on a running motor! 1 of 10...now the other 9 have something to aim for.
sycho
workin on it mike! :tup:
thats a good feeling when you get to this point, hard part over! awesome:tup:
Windedv6
Ty n 10s
So I saw you drilled your Bowtie block for oil returns up in the lifter valleys is that somethIng that is recommended for these Bowtie blocks? Haven't read or seen anything about it till I saw you did it and i have the same Bowtie block going to the engine builder this week and am wonder if I should have him do it?
I open the same holesmy bowtie blocks. These block were originally cast for dry sump closed valley to keep oil from running down on the crank and cam. For street use and wet sump setup it is better to allow some oil to return down through the motor. It also helps vent the pan area pressure.
John
denny
On the vid, looks like you have a big kink in the upper rad hose.
yes, a little kink but not too bad.
Planing on redoing the intercooler pipes and that top radiator hose, its too close to the belt.
Decided to ditch the AC, not enough room, got to get a AC bracket delete kit.
Still have a lot to do before it can be driven.
denny
Few updated pics
sitting in the backyard waiting waiting for hurricane Irene to pass
denny
My ty is possessed, every time I fixed something, something else happen.
Today the intake is leaking, after a few 10 lb boost, i think the upper intake warped.
But not before I swaped out the distributor lastnigh, Autozone free lifetime replacement is the sh*t. it sounded yesterday like metal grinding, 'kind' of happy today.
before that, metals in my oil filter.
it was probably from the PTE billet turbo which had to be rebuit twice in the since the new engine.
the other week i had some drag radial mounted on the zo6 rims and the shop damage one tire, had to fight a bit to get some money back.
i have block off plate but this thing is still leaking
