who's crank? Is it a GM piece? Nice dude!!
Not sure, I bought the crank here on the fourm, that person bought it from someone else. I think its from crankshaft specialist in Texas, maybe.
Hi Denny
How did the crank balance out. I know some of them needed a bunch of weight / other didn't .
ps - subscribed
Looks good. I assume keeping it a 4.0 bore?
Hi Denny
ps - subscribed
Not trying to be an A$$.
Are the pistons Wiseco? http://www.wiseco.com/
You are using Vortec cast iron heads?
I would use some other aluminum heads, if those are Vortecs,that's waht will be limiting your power output.Aluminum heads can allow to run higher compresion.:2cents:
Nice build on the other items.:tup:
