Re: Crazy Freeway Knock Retard
Has this truck ever ran without any KR? You mention that it ran good when you first bought it, but don't mention if you data logged it back then?
The reason I ask is because my old truck behaved very similar to yours and I went through a lot of what you did only to find out my problem was the compression being way higher than stock. I ended up using alky to eliminate it for the most part.
http://www.syty.net/forums/showthread.php?t=87503
I did do some datalogging shortly after I got it. It was bone stock at the time (2009), minus fresh AC Delco plugs, cheap duralast plug wires, and a delco cap. It would get 0-4* if I put a little race gas in it. All this with a 195 t-Stat and a non hot-wired IC pump. I never even bothered to check the timing.
I haven't done a compression check on it yet. I'll add that to my to do list. I haven't had much time to work on the truck with life and work. Seems like I can try about one thing a week these days, then I'm trying to fix new problems. I'm currently chasing down new problems:
1. IAC code, rough idle, stalling, stock IAC was stuck, took it out, caked with carbon, cleaned passages, replaced IAC valve. No more stumbling, now has high idle. 1100 in park, 800-900 in drive. Occassional IAC code 35. Tried the aldl jumper reset. no change.
2. Super lean Sterm counts, sometimes as high as 200, at cruise and idle. Base fuel pressure all the way to 50 psi. Have tried everything form 43-50#. Smells pig rich at idle. Fuel pressure rises with boost pound for pound. I even made a video of it.
3. Datamaster all of a sudden does not want to do a pcm sync. I got it to datalog for about 5 min tonight after messing with it for 2 days, connection died before I could get into boost. It never came back.
I swear this truck is getting sold once I fix these problems!! I've even got the ad drafted up.:rant:
