nello
I've noticed quite a few people using the innovate LC-1 Wb02. What I can't figure out is if you guys are using the real time display like I have in the gauge pod...??? Since I use this display all but one of my connections are used. Meaning I still have the yellow analog out wire available. Everything else is grounded or connected to the pod display.
I also have the stock 02 sensor still installed, untouched and working. A second bung was welded to my downpipe so my LC-1 02 sensor is completely separate from the still functioning stock 02.
So the question is, will connecting my final analog out to the F14 give me AFR? What about the B9, is it necessary? I don't wanna lose my display pod or fry my ECM.
Here's what a write up on code59 says. Only mentions F14 connection for LC1.
"....and now the LM-1/LC-1 is ready to work with Code59. Make sure that the output you programmed is the one going to F14 on the ECM." And thats it...?
thx
thx
