Hi guys,well just put a fresh engine in my syclone started it, started fine idles good and then the famous water in the oil curse,first set of of intake gaskets were the edlebrocks,second set were felpros 1203, just orderd,felpros 1268, I used the red rtv the first time and the right stuff the second, My question,is there a way to know if its coming from the intake or the head gaskets the truck has 94 heads, the truck starts up fine has good idle, I bring it up to temp, If it wasn't for the water issue you could swear there wasn't anything wrong.
