10secTy
Sy-Ty builder and Tuner
Re: syclone engine build (with pics)
One thing to consider is if you swaped from the larger TB to the stock one this will help your problem. Alot of people runing the large Ford TB have problems with this due to the the fact that the TB is so large opening it 1/64th will move way more air than a stock TB.
Also make sure your Ve map is not pulling out to much fuel with BLM's (if you run closed loop). If you are crusing around and the short terms are pulling say 15% then you accelerate and get into a part of the table that is leaner your AE will not have enough added fuel to compensate for the flat spot.
When I did Tonys truck I was burning chips the old school way and took 54 of them to get it right. Keep pluging away and you will get it sorted out.
Nolan
Nolan
