Starting My engine build!
Six-is-Enough
Use to do a little Boost
Re: Starting My engine build!
Jeremy, what is your build going to consist of in the long run? What turbo etc..
Nothing to exotic. Self ported L35's, custom Comp cams to my specs, Eagle h-beam rods, Speed pro forged pistons, Stock intake and intercooler, and Stock turbo too start off with. I have a 20g with a 57 wheel to install later, but first I would like to try and eclipse the fastest Sy/Ty with stock turbo et of 11.48.:D
Aeroking
e.i.
is the crank treated?
i did the same build, and i always think back that i should have treated the crank.
Six-is-Enough
No. stock 4.3 crank turned .010/.010. The crank out of the sy block from Daron was cracked to hell.:tdown:
Six-is-Enough
Finally got to do a little more to my engine build. Been busy with the Holidays, Vacation, 15th wedding anniversary, and expected death in the family(Great Aunt had been very sick for awhile).
Got the rods & pistons in hope to get cam in and degreed by end of the week!:tup:
Six-is-Enough
************************Update******************************
Progress is slow, but I am in no rush. Got cam & timing chain installed and degreed in. Set up straight cam was 119. Adavnced as much as I could. Got it set up at 115. Also got oil pump withpick up installed. i'll get some pics tommorrow.:tup:
V6 Kompressor
Did you have any clearance issues between the eagle rods and block/cam? I didn't but I have heard some did. Did or does your engine guy run a super stock drag car?
Six-is-Enough
Clearances was on the edge .060 or so . Proabale could have left the block alone but went ahead and clearance it for the rods. No issue with the camshaft and rod clearance.
Yes my machinist is Jeff Taylor and yes he is a past 4 time world champion Super Stock racer.:tup: BTW I am doing the assembly on my engine.
Six-is-Enough
It's Tomorrow.
PICS?????:rant:
Demanding................................................
Cam installed
Balancer being installed
Checking balancer mark for Top dead center
Last time I want to see this view
Six-is-Enough
Oil pan ready for install
Note clearancing for eagle rods to pan
Pan installed and bottom end DONE!:D
Now onto porting cylinder heads.:(
SY-1193
Thanks for the pics. You beat the $#*! out of that pan! Shouldn't be any clearance issues there! Venting some frustrations?
No Glyptol in the lifter valley took you for an old school'r?
That block needs some color.
Keep the pics coming...motivation for me to go do something on mine.
Six-is-Enough
yea...what's the status?
It is done and running, but has a severe oil leak from around the oil pan.:rant: Just have not had the time to drop front dif and pull pan off to replace gasket. Hope to mess with it here in the next month.:tup:
Six-is-Enough
Update: 6-5-2011
Got the front dif removed today and pan off.
Going to put old pan from orignal motor on. Got it cleaned and clearanced today also. Quit working on it today so I can be fresh and thinking clearly when install it. Don't want to have do this again!!:rant:
qbnkiller
Conflaguration Specialist
rightstuff is your friend....I always use it on just about everything now...
cheatham2492
I have to do all the same stuff you do.. Kind of a chore isn't it.Very rewarding when its finished . Nice job
Cheatie
