Starting My engine build!
Six-is-Enough
Use to do a little Boost
Been collecting parts for awhile now. Time to get started.
Jeff Taylor Performance performed the machine work.
Using Pro Gram 4 bolt main caps. Thanks to Campbell's Automotive!
killerrudy
Re: Starting My engine build!
I want one! If you make two then you can share...and it is the time of the season to share :)
Six-is-Enough
If I was standing to your right (the side where your thunb is) and looking at the grinding wheel at a perpendicular angle, is the wheel spinning clockwise or counter cw?
Counterclockwise. You should file towards inside of ring and also file off any ridges that form on the edges.
Tony Dipatri
Hope it turns out well Six...Good luck.... I have a few questions you may be able to help me with...I have a blown motor and will be needing a block which from what I read is the same core as a regular Jimmy 4.3. The manual says that the crank, cam, rods, pistons, caps, heads and valve train are different. the performance machine shop is telling me that just the pistons and rods are different... I am trying to locate after market parts that meets or exceeds the stock parts...I can't even find a hardened crankshaft...If you have any information please repost
thanks
Six-is-Enough
thanks
PM sent
Six-is-Enough
Got a little more done today.
Crankshaft set in and torqued down. Crankshaft was switched from external balanced to internal. Bearing clearances are between.001 & .0015. Thrust bearing to crank clearance is .0015.:tup:
Good Shot of Program splayed caps:
Pic of cap notched for dipstick clearance:
Jeremy, what is your build going to consist of in the long run? What turbo etc..
Ty 1885
Just a thought, according to JE pistons, gapless or total seal rings should NOT be used in boost app. They say that boost pressure can build between top and 2nd rings cusing the top ring land to break.
Also the 2nd ring gap should be bigger than the top. Top .020 second .022
Six-is-Enough
These are not Totalseal gapless rings. They are traditional gap rings. As far as the 1st & 2nd ring gap, I am following ring manufacture (toatal seal) recommendations. Which for boosted applications are bore (4.030)x .0055 for top ring and bore x .0035 for 2nd.
