mattw
Re: Photoshopped picture?
So now that I have everything apart and can take measurements I've decided to not even use the wastegate port on the back of the PTE housing.. It is only 26.8mm(1").. It could be ported but you would never get it to 50mm and still have enough surface left for the downpipe flange to actually seal. I am just going to block this port off and tap my manifolds where I can get the whole 50mm.. This is where/how I plan to do it..
I will purchase a 50mm v-band wastegate and mount it to the top of the pipe. I should be able to plumb the return back into the downpipe 18" from the turbo..
I want perfect boost control so I am trying to do this right.. No more blown engines!!!
Thoughts, suggestions, recommendations?
