Re: Photoshopped picture?
So I did some work installing the WBO2. I ended up going with the PLX unit. I didn't realize this but you are supposed to mount the sensor ~36" downstream of turbo and at a 15 degree angle instead of perpendicular to the exhaust flow. The bungs that I had pre-welded into my downpipe were way too close to the turbo and not at the 15 degree angle..
So here is my new location with the proper 15 degree angle:
I finally finished my hydroboost lines.. I'm happy to report that the for Rack and Pinion unit seems to work perfectly with the S10 power steering pump and Astro Van Hydroboost unit..
So I have a bit on an exhaust leak issue that you can see here:
When I welded my manifolds I bolted them to an old head hoping that would prevent warping.. It didn't.... So after I welded them I tried to re-surface them on this belt sander:
That seemed to work OK.. If you lay them on a flat surface they appear to sit flat but obviously they still leak..
I hate exhaust leaks and will not leave it this way... The passenger side seems to be sealed up well.. The drivers side leaks. What do you guys suggest I do?
a) Should I spend more time on the belt sander?
b) Spend more time on the sander and use gaskets?
c) Quit being cheap and find a shop that will machine them perfectly flat(I suspect this will cost $150-$200 ish)
