Re: Engine "stuttering" under full boost - see dm file
Just posting the follow-up for posterity's sake. I always hate searching and finding a thread with no conclusion. :roll:
So I put the turbo back in, cleared the 42 code and re-did my wiring. Turns out I had a wiring issue from the WBO2 to the ECM. The gauge was right (i.e. was running rich) and the lean readings in dm were wrong. At the same time, I put in a fuel pressure gauge. Fuel pressure is 43 cranking and rises to about 62 when under full boost.
The run is below. I finally have solid boost control.
No cat and free-flowing exhaust can, indeed, be fixed with the Forge wastegate and some conservative port work. Also, I found that the truck had been rich when I got it (hence the 120+ injector duty cycle). Now, things look pretty solid. Thanks for all the help. I have a few tweaks to make, but am calling the truck good for now.
