E.Murray
The truck was having boost control issues when I got it. No cat and Sportmachines billet impeller worked together to make sure the stock wastegate couldn't bypass enough exhaust, leading to overboosting and wavy control. I got the Forge Billet wastegate and did some port work on the wastegate side of the turbo. It pulls great under part throttle and light boost, but I can't get above 13-ish psi and there's a high frequency "stutter" I can feel when I put the boot in it. I'm hoping some more experienced eyes can pick up any oddness in the datamaster file. Yes, the injector DC is high, but I'm still a bit rich, so I'm not concerned about it. I know I can also crank the spark some, but I want to get the boost straightened out first. Where should I look?
