wildphil
I Love My Ty's
Re: Engine stumbling
If you hooked power to that jumper and the fuel pump does not kick on then the relay is not the problem. Because by applying 12v to this jumper bypasses the relay.
Try this test again and have someone listen at the back of your vehicle for the pump coming on.
If it does not run. Then make sure you have power and the ground is good at the tank for your fuel pump. If you do them your fuel pump is bad.
Now that I think a bout it I put power to that terminal before. nothing happned. What type of relay is this thing is it a typical replacment. I know the 2 up by the fire wall. The one thats closer to the intake manifold has this weird splice connector on the yellow wire and looked out of place to me right from the start. Might be the AC relay or th FP. Can I plug in the other one?
