Don W.
Couple of engine removal DAQ's: Am I better off removing the engine first then the trans or the trans first? I have solid mounts so I suspect that the engine will just sit there on its own after the trans is removed. (Or I can easily support it.) Anyway, Monday (tomorrow) should be moving day and the Sy should be apart one way or the other soon after. Although the trans was still shifting hard when when things went south I'm thinking I might as well do the trans while I've got things apart.
Thanks.
Thanks.
