Wont go into 1 or 2 manually
NOWAY55
Ok, what would cause me to not be able to move the selector manually past D down into 1 or 2 ?
It seems like it shifts fine on the street going up through the gears. Light throttle 1-2 is around 15 +- 2-3 is around 30 I think
The other thing is that it doesnt seem to downshift very well when you get into it on the highway unless I am just not feeling it.
Any help or suggestions are greatly appreciated.
Re: Wont go into 1 or 2 manually
On stock motor and on the highway, SyTy usually only downshift to 3rd gear. (I think the last time my SY would down shift to 2nd gear is 45mph)
lavaman
envision whirled peas
If you're talking "physically shifting" the lever, then maybe if the lever on the trans itself had been altered "wrong" to accomodate a Gilbert Propshaft so now the leverage ratio is changed.
jhj
When I bought mine it was very difficult to get to go into 1 or 2. The problem was that shifter cable was badly rusted and about to break. After it was replaced it works great.
I would highly recommend a new cable. I hear George makes a nice one. What you will also want to look at, it the P/N switch, it a plastic tab that fits in the bottom of the shifter and sometimes they are not in there.
supersports10
i make a aftermarket shifter cable also, in stock ready to go 165 plus shipping + 1 year warranty.:D
