Wierd radio issue
gkrcr882
SyTyless......for now!
Ok, just installed a factory radio bought from a fellow board member, radio works perfectly. Problems are listed below:
1. Turn on dome light, radio freaks out, display messes up
2. Shut off truck, all presets are lost
3. Open door (turns on dome light) same as #1
4. Foglights don't work
5. Remove dome light bulb, radio doesn't work
I think there's a short somewhere, since we had to splice in the connectors for the radio since the originals were cut when we bought the truck. All fuses are good, no problems before we put the radio in.
WyoSyclone
Re: Wierd radio issue
....you may have your illumination wire hooked up as your radio ground
.....you have your radio's battery lead connected to the ignition lead
.....see number 1
....radio is grounding itself through the illumination circuit, only when the switch is off.
sy2207
.....see number 1
Agree 100%
sy2207
Radio 12v orange
Radio Ground black
Radio Ignition yellow
Radio Illumination gray (dimmer)
Factory Amp Turn-on pink
Power Antenna N/A
LF Speaker + tan
LF Speaker - gray
RF Speaker + lt. green
RF Speaker - dk. green
LR Speaker + brown
LR Speaker - yellow
RR Speaker + dk. blue
LR Speaker - lt. blue
gkrcr882
THANK YOU!!!! I tested the cig lighter along with the 12v for the radio, and got nothing. After reading your reply, I went out and checked the fuse, and its blown. Again, thanks, you saved me from thinking I had a major electrical nightmare
JAY
I had the exact same problem and I thought the worst. I came in read some posts and found my answer. I had my test light & multimeter ready for action.
