Where and who....
kraus
I bought the wife a 92 Ty and was told it had 75 lb injectors but we all know how that goes.So I did my own digging
Okay here are the mods i found so far. I pulled the computer down has a KENNE BELL chip part #8026. It has a j&s electronics knock detector thing in the glove box also made by Kenne Bell,it has a dial for sensitivity,and rev limit.. It has a 3 inch cat back exhaust.A 255 lph fuel pump, Kenne Bell regulator and fuel pressure gauge.I t has a front mount intercooler,mounted by front bumper area.And the injectors are red couldn't see numbers on them,guy got it from was told they were 75lbs,but who knows.Msd coil and wires also kenne bell air intake. It has 17 inch ZR1rims all the way around out back are bald 315 35 17 up front are 275 40 17 no idea back spacing but rear rims do have a wider lip out ,
Obviously i need a chip where and who do I talk to ?
so do i put 275 on rear or stay with the 315's?
thanks in advance...
kraus
Re: Where and who....
jwaller said:
send it to me I can reburn it for you.
Will do John as soon as i figure out what injectors I got and unwire all the J&S crud,and the aftermarket alarm that won't let it start now.GRRR Idiots that wire stuff they no nothing about piss me offf.....
turbodig
I've never seen a KB anything other than stock injectors and 40#. Not that there couldn't be, but it would be a very rare bird if it was.
Get the numbers off the injectors... that'll tell the tale.
akwilks
Mr. Keith
Yep, the 50# injectors that supposedly came with my truck were red and they were 30lbers.....Needless to say they were removed in favor of real 50lbers......
kraus
well got j and s crud removed,alarm removed and it runs and drives again still some minor issues to solve with wiring.But it is running again at least.I am going to look tommorrow for injector numbers so I can post em. thanks for the help so far guys...
Tooky
Serious about performance
Are the tops of the injectors red? C'mon man, throw us a bone here..
alwayscode390
pppssssshhhhhtttttttttttt
I dont think 275's will fit on those 12" wide rear rims. I think you must replace them with 315's. 275's would also be taller ... and you cant have different diameter wheels up front and in the rear ... its hell on the t-case ---
kraus
the rims i had them off they are a 10.5 rear and a 9.5 front..
Flyin Ryan
hated cuz he drives fords
you'll need 315's... 275's are the widest I could go on my wheels and there 9.5 wide
