does anyone know what part number for a lokar engine oil dipstick will work for our trucks.
S syclone0209 Member May 20, 2008 #1 does anyone know what part number for a lokar engine oil dipstick will work for our trucks.
TYHOGG Active member May 20, 2008 #2 Re: what part# for lokar engine oil dipstick I think its ed-5001. mines sitting on the shelf at the shop i'll double check.
Quickstop [UK] Combating adversyty. Feb 6, 2009 #3 Re: what part# for lokar engine oil dipstick Is this correct? I broke mine and need a new one
TYHOGG Active member Feb 6, 2009 #4 Re: what part# for lokar engine oil dipstick I've put my truck on the back burner. If the dip stick measure more than 6 1/4" exposed (part in oil pan) then it will work on our trucks according to Lokar. It looks like the ed-5001 will work fine it has 6 1/2".
Quickstop [UK] Combating adversyty. Feb 6, 2009 #5 Re: what part# for lokar engine oil dipstick thanks mate
Quickstop [UK] Combating adversyty. Mar 25, 2009 #6 Re: what part# for lokar engine oil dipstick couldn't get mine to fit, at least not with the manifolds on.
bezerk New member Mar 25, 2009 #7 Re: what part# for lokar engine oil dipstick Quickstop [UK] said: couldn't get mine to fit, at least not with the manifolds on. Click to expand... lol. couldn't you grind your way trough?:rotf:
Quickstop [UK] Combating adversyty. Mar 25, 2009 #8 Re: what part# for lokar engine oil dipstick you laugh - it is a bit too long with the manifolds so I ground off an inch - the actual solid tube on the lokar piece is too thick - fractionally.... typical...
