GEN3Typhoon
Does anyone know if a stock water temperature sender, like the one in the head of the truck, is the same resistance range as one you would use in an after market temperature gage...
My water temperature gage does not work of course and I would like to swap in an extra one that I have to see if this will fix it.
I hate my engine temperature gage does not work right.. when it is at 160 it is barely off the first mark. Was not sure if this was something that happens or just corrosion on my temp sender in the head or something.
TIA
TIA
