Turbo Reccomendations??????
turbosonoma
Ok after finnally digging my truck out of the garage after a two year hiatus and driving it today I am sort of motivated to finish it and make it fast. This is what we are working with:
2WD
3000 stall
eagle rods
srp pistons
4 bolt mains
ported vortecs
comp 412-8
walbro 255
50# injectors
afpr
dfi
So the turbo, manifolds and ic and exhaust is all stock, I want to get a new turbo that will actually match my build, but i dont want to do the headers and air-air right away. So i want the biggest turbo i can get without over doing it, ive been out of this syty thing for a while so i cant remember whats what anymore. Once i do the turbo i also need to do new exhaust will single 3" with a muffler suffice fine?
Thanks
Brad
BigAl...
Well except for the injectors, Tony (eh) went 10.71@126mph with a T72P using the PTE exh housing. of course he had the supporting cast fuel pump, tranny, yada yada yada.
BigAl...
turbosonoma
ok well that doesnt help to much, im not planning on changing anything that i already have besides IF needed i can get the stall reworked a bit, for now i plan on keeping the fuel sysytem the way it is. Ok in other words what is the biggest turbo i can run on 50# injectors and a stock fuel system with a walbro 255??????
Need help here guys...
E-Rue
PT51, PT52, PT61, GT35R, PT67GTQ
e
10secTy
Sy-Ty builder and Tuner
Slow-Clone said:
Think he had the benefit of 3500 stall also.
We are now running Pt-74GtQ turbos with 2800 stall and they spool up great. Tony is also running a 2800 now with the t-72 and spool is just as good.
Nolan
Innovative 76 dual ball bearing....
I've got the low stall convertor and shitty 50#ers as well, and I still say it's the most fun I've ever had in a SyTy. I have the MikeLee 3" DP with Progate and a 3" Dynomax bullet, and it's plenty of exhaust.
I'm not sure how the 76mm could cope with the tiny stock IC
The Dustan kit, Wilwoods, Weldon, and roll cage are next on my list to install, and I'm sure the 8s are just around the corner :)
7's for October in DragRadial form is the goal, but who's counting?
Rare91
Are you high????
Are you high????
Keep dreaming.......lol
Jeff H.
