Turbo Oil Feed Line
Ty Pilot
Ok, I have gone through the search results and got mixed information. I am looking to replace the stock Mitsu turbo oil feed line and need size information for the hose and -AN fittings. Looking to confirm, as I obviously want to get the right parts the first time out. Admittedly, this will be the first time I'm going to be making my own fitting/hose setup.
For the hose I got search results of -3 AN and -4 AN. Which do I go with?
For the fittings I have seen 1/4 NPT at the block and 1/8 at the turbo end.
Thanks in advance.
jpz06
Re: Turbo Oil Feed Line
I used a 1/4 in.superhose from the local refrigeration supply store,the only difference is one end is straight and the other is 90 deg. bend. they have them in different lengths.
