while rebuilding mt front end, I removed the torsion bar mounts and noticed that they were modified. A cross brace was welded on (spaning the mount perpendicular to the length) and a rubber flat washer was used under the mount (between mount and frame)
Question is, are the stock (moog) rubber mounts that prone to failure?
Is this a common mod?
Should I put the modded mounts back (not use new rubber ones)?
How much does this affect overall ride?
thanks
tim
thanks
tim
