Motocam Syclone / Typhoon Plug n Play ECU : Stage 2 E85 with coil pack distributor delete
Typhoon upper, mating surfaces fly cut/squared
Billet wheel 9-11 3" Anti Surge Turbo GMC Typhoon Syclone 4.3L TD06S-18G 8cm w/ Burger Motorsport BMS turbo mount filter
6 Signature Series 80 LB Deka from Fuel Injector Connection
COMP Cams Pro Magnum Hydraulic Roller Lifters 875-12
Crane Cams Gold Race Rocker Arms 1.5 Ratio, 3/8" Stud (Self-Aligning)
Quantum E85 340 fuel pump
6 Eagle H-Beam Connecting Rods (used)
Reman 4.3 V6 262 VORTEC Heads
Welded lower intake
Stock exhaust manifolds
4 bolt main caps
Waterpump, damper, Power steering pully all new gm
See link for 30+ pics
located in NC
$3000, not looking to sell anything individually
Welded lower intake
4 bolt main caps
located in NC
