Throttle body hose problem
sytygmc
my throttle body hose keeps coming off whenever i floor it. ive tightened it down as much as possible but it still keeps coming off. any help would be appreciated. thanks.
InvisiBill
You should have three brackets underneath. If you're missing some, the CAC can shift and make the hose pop loose.
sytygmc
thanks for the help guys. the bolt under the cac fell off and i replaced it. however i found a hole in the throttle body hose now. i called gmc parts and they dont carry it anymore, same goes for local parts stores. last choice is atr. does anyone have a alternative solution. thanks in advance again.
