A shorted solenoid, relay coil, or harness in a GMP4 computer will not damage the ecm, but will cause the circuit and controlled component to be inoperative. When the circuit fault is not present or has been repaired, the "quad-driver" will again operate in a normal manner due to its fault protected desgin. If a fault has been repaired in a circuit controlled by a "quad-driver," the original ecm should be reinstalled and the circuit checked for proper operation. ECM replacement will not be necessary if the repaired circuit or component now operatres correctly.
