Tach jumping?
912091
At idle my tach jumps 3-4 hundred rpm. Ignition is all new and so is the iacv. atr chip, 160 and a k&n cone
GM TURBO
Sell Out
Pull the ECM B Fuse for a couple minutes.
Plug it back in.
Start the truck.
Let idle for a few minutes without touching the gas.
Turn on lights, AC and any other accessories to allow the computer to make any adjustments needed with the system loaded.
Run Datamaster/Diacom and see what is going on.
Replace fuel filter.
Check fuel pressure.
Loeryder
Tach Dance = Ignition problems.
If it jumps around while "feathering" the pedal you have igniton problem.
Check for cracked insulator on one of the plugs or a wire not hooked up right or bad wire out of the box.
it all has happened before.
just have to narrow it down.
