John i actually need a turbine wheel and the center section. I wont need the compressor wheel cause i use the 58mm one. It was a Jimmy 2 turbo on a Opel GM i installed.
The mechanic removed the blow off valve and the front nut got off after the race.
I did sell my old T67 to this guy but he needs the mitsu repaired for his cosworth
alright if all you need is a good turbine wheel and center section I have several of those. the turbine wheel you want the stock one or the "H" wheel? I have both. sounds like about $150. the turbine wheels are getting harder to come by as I've had to replace a bunch of them recently.
