still need help
frisko
ok i got my sy awhile back and had some 96 vortec heads put on it.as well as all this stuff that was in it when i got itfrom seller"
4 bolted block with Milodon Nodular Caps and ARP Studs
Shot peened and nitrided crank
Eagle H beam rods
Speed Pro forged turbo pistons
Fully balanced rotating assembly
Fluid Damper
ARP head studs
Comp Cam – Rockford Racecraft grind
75lb injectors
Fast engine management- laptop tuneable
Applied Technologies and research headers
Polished precision 54 turbo
Precision turbo downpipe with cutout
Kenne Bell 3” Exhaust
MSD ignition and coil
Rockford Racecraft billet fuel pressure regulator
Rockford Racecraft fuel pump
Applied Technologies intercooler w/ sureflow 24/7 pump
RPM turbo drain back
Built Transmission
B&M Transmission Cooler
Heavy Duty Remote oil filter lines
Rockford Racecraft oil pan
Rebuilt front axel shafts
Rebuilt rear drive shaft
New Radiator
Applied Technologies cold air kit and battery relocation
Auto meter electric fuel pressure gauge, boost gauge w/ peak warning, and trans temp gauge on 3 gauge pod on driver side a pilar.
Greddy Profec B-spec 2 boost controller
Approxamatly 500 hp, it has never been on a dyno. I have well over $20,000 into the drivetrain. "
ok thats alot of stuff right!!! and it should fly if it had wings but (and i'm a first time sy owner) it dosnt feel now where close to "running" it has a sputter on take off doesn't keep you in back of your seat till i let off the gas.
so i think it might be a combination of to much or not enough gas,spark,fuel, air, to big of injectors????????? the guys that supposedly fixed it/installed the 96 heads. tuned it in and well like i said its not where i think it should be.
so if anyone has any ideas or knowledge about how to go about this please let me know. im in tucson, AZ now.
PONYKLR
I thought I left Colorado
Re: still need help
Trailer, northern California, Advanced Dyno. Robert is a genius on the dyno. Especially with forced induction and nitrous tunes. Make a short vaca out of it.
mandingo
She's an Alcoholic
Re: still need help
Wow, looks like you have a lot of nice mods, what have you done so far as tunning and tune up, "sputtering" sounds like ignition related?
frisko
Re: still need help
man the guy that "tuned it" did the fast management and supposedly everything needed???
Re: still need help
You really need to get some sort of scan tool (tunerpro, tunercat, datamaster, etc.) so you can see what's going on. Take it from me I just spent $5k on a new motor because I wasn't "sure" what was going on, and I drove the snot out of it. Don't do what I did!!! Drive it as little as possible untill you know what your motor is doing, or you WILL be bummin!!
