Steering wheel smoking?
I have no idea what this is but I noticed it after I hooked up my Alky kit. When I get on it, I see this "smoke" come out where the steering wheel is attached. Its really weird. It doesn't smell like something is burning or anything like that, almost looks like some kind of dust but hard to tell. Anyone have any ideas?
12secondSY
Syty Killer :(
Re: Steering wheel smoking?
This is probably no help but I had my first V8 S-blazer catch fire once. It only melted one wire but I only noticed it coming up past the steering column and nowhere else. Anyways I'd bet its coming from under the hood and willyson could be right on this one. Do you have a PCV system or just breathers? I had a lot of smoke come from the breathers on mine before I rebuilt the engine
Xtrempickup
All turbo All the time
is that the early stages before the Goo starting coming out of the steering wheel
NJ93TY
I would check your turn signal switch. A few years back i worked at a chevy dealer and had a corsica that the customer complained of smoke comign out of the steering wheel. I removed the wheel and found the turn signal switch was black and burnt. I would remove your steering wheel and check it just in case.
Raist103
Engine Killer, iPhone Killer, Lawnmower Killer
had that happen once and i did smell burning but never came back so i did not worry about it
91blazins10
willyson said:
x2 I had this happen to me when my engine was dying, engine smoked really bad under wot and all the smoke came through the steering column because one of the rubber grommets in the firewall didnt seal well.
Good suggestions. I suppose it could be the blow by but how come it doesn't smell like anything?
Tooky
Serious about performance
I used to have a 93 Cavalier Z24, that would make smoke like you describe, occasionally when I hit the turn signal.
How did I know someone would bring this up? :silly:
:rotf: Funny thing is that it only happens at WOT, but not all the time. I am going to re-direct my vent tube on the DS valve cover and see if it does anything.
Jamerjoe
x2
sly dvl
Ya, it's got a Turbo
X2
Mephisto
These trucks are cursed
sometimes the steering column will smoke if you're low on turn signal fluid. Half quart of Prestone should do it.
