Steering problems
I replaced Everything Steering except gear box all new tie rods, pitman arm, idler arm and A-arm bushings took it in for alignment and the they aligned it to where the pitman and idler arm are parallel and did the alignment now my truck wont turn left tight maybe its the wrong pitman arm do some have different splines in them..or is there a Typhoon Specific pitman arm.
Be advised its the Second time ive taken it to get aligned and they dont even understand why.
Re: Steering problems
I got it done at Firestone my alignment I am not the original owner maybe the previous owner worked on the gear box and its not correct inside. and another question what it the little allen bolt on top of the gear box for?
believe me it looks correct i even watched them do it. the gear box bottems out when it turns left.
jjorgensen52
NHSTE - I'm the only one!
has the steering shaft ever been removed? If it has it may be off centered. The box should not bottom out turning either way. It ought to have at least another 10 degrees of arm pivot to it. It is also possible the pitman arm is on 1/4 turn out of alignment (IIRC the box has a raised spline and the pitman arm can go on it at 4 different positions)
