gjp
another post whore
I am getting smoke in valve covers. A small amount of smoke is in both valve covers. I removed both breathers. I have no pcv system right now and I see a small abount of smoke billowing out of both covers. I put a piece of paper over the holes to see if there is air pressure. Even at 200rpm the paper juts vibrated about 1/8th of inch. I had more air leaving before the new heads but I dont remember ever seeing the smoke. I did the top end build but left the bottem end stock because the compression test before the build was good. 140-146 on all 6. I figured that was good. When I removed the pan I saw no metal. All the pistions were cleaned and everything look fine. I was actualy surprised to see how clean thing was in fact. The oil now is still clean after about 50 miles. Truck runs good and strong. idle is good but not great. Good for a Sy. 750-800rpm. I havea oil leak out the rear but It looks to be the oil sender where it meets the block (thin tube).
Is the smoke normal?? Heads were bought built from a member on here. Could itbe the valves are adjusted wrong. Truck runs good on 18psi with minimal knock (1-3*) on 91 octane and no alky. Boost launched @ 10lbs with no knock. Got a few deg. on shifts but would taper off. Engine idles @ 14.7. WOT it runs around 11.3. Again with no alky. I am new to engines. Not sure whats wrong. I need Help. I searched and found it could be the rings. I do get a bit of oil on valve covers but they are non baffled rpm covers.
I will do a compression test. And a leakdown test if I can find the equiptment to do so. ANd if someone can tell me how. You guys always seem to help. I Try to do my part to pay you all back by giving away parts and help with what I know. Thank you in advance, Gary
