Smaller/Less powerful power steering pump?
Daveman2
Autox Blazer
Hey I was wondering if it's possible to run a lower power, power steering pump. My steering is pretty light and I still have my transfercase, rear step bumper, and some other components to lose, so I don't need as much power as I did stock. I definitely can't swap to manual, any of you guys running vette wheels know how impossible that it is to turn out wheels when the engine's off.
Is anyone running an aftermarket p/s pump?
I figure a smaller and less powerful pump might give some power gains and weight loss, and give a heavier more connected feel with the steering.
sytyguy
Moderated User
Re: Smaller/Less powerful power steering pump?
I have one of the J-Body pumps, and it is much smaller/lighter than the stock pump.
or
Not that I consider the stock pumps inadequate or overly heavy, but for my '64 Chevy II (that had the Syclone engine in it), this was the pump that I used. Lots of hot rodders use it with a remote reservoir, otherwise you can go with the stock reservoir, but it gets bulky at that point (see below).
or
warmpancakes
I was considering a astro pump for the remote res, whats the application of the J body pump? and just use the res form a astro van?
sytyguy
Moderated User
1996-2004 Cavalier/Sunfire (give or take a year).
A1 Cardone #s - Pump only - 20-500 or 20-888
A1 Cardone #s - Pump & Res - 20-54500 or 20-70888
Daveman2
Autox Blazer
How did that affect the steering feel?
Thanks for all the info BTW
sytyguy
Moderated User
Keeping in mind that this was on a '64 Chevy II with 235s on the front, it was fantastic feel. The pump is plenty powerful....in fact, I have a friend with one on a road race prep'd C4 Vette (with 315 Kumho Ecsta V710s on the front) and even at terribly low speeds, the pump does the job.
Daveman2
Autox Blazer
well do you think you can be more specific? Did it get heavier or lighter? did it feel more connected with the road, or more smooth and relaxing? And how did it compare to the previous larger pump?
sytyguy
Moderated User
Do I think I can be more specific? No....I don't think I can.
You hafta understand that I yanked an Inline 6 with no power steering out of this car and put in a SyTy engine with this pump and a Mustang II rack and pinion. So......
Did the feel get lighter? Yes.
Did it feel more connected? Yes. (The stock Chevy II suspension was barely connected to itself, much less the road)
More smooth and relaxing? Yes.
Compare to the larger pump? Can't.
But, those responses aren't helpful. My buddy praised this pump for it's characteristics on his Vette, but unfortunately I don't have any before/after data of the Saginaw pump and this pump on a SyTy or S-Series in general. Not sure that anyone on here does. I personally can't imagine that the feel would be drastically better/worse. The size and ability to run a remote reservoir are what make this pump attractive. So, my suggestion was more aimed at the "smaller" aspect of your original post.
