Setting TPS
TyFun
I don't have a scan tool yet and I think my TPS is off some. I used to know but have forgot how do you check/set the TPS idle and WOT with a volt meter?
Thanks,
Steve
Daron
TPS isn't adjustable. When you key on, ECM reads TPS resistance and that becomes 0%
Daron
RealFastV6
@jb_and_his_coffee
Re: Setting TPS
You can backprobe the blue and black wires to check it. Same as a GN, F-Body, Corvette, and many other GM vehicles of the same era.
TyFun
Re: Setting TPS
So if it is like my GN it is adjustable. I adjusted the GN with a volt meter before I bought the scanmaster. The volt meter should read a certain voltage at idle and another at wot. I just need to know what those numbers should be. Mine is idleing a little rough and it is bogging at wot. It runs best at just before wot. I just want to check to see if the tps is where it should be before I look elsewhere to fix my issue.
Thanks,
Steve
Daron
It is not like your GN. Check it with a scan tool.
TPS is not your rough idle or bogging at WOT prob.
Daron
RealFastV6
@jb_and_his_coffee
Re: Setting TPS
Read more here, especially the last post. http://www.syty.net/forums/showthread.php?t=69585
Unless you're throwing a code it's not likely there's anything wrong with what you've got.
What feels like bogging at WOT but not part throttle could just be a sign of knock retard. You really should hold tight until you get a scantool and a boost gauge.
TyFun
Re: Setting TPS
Thanks for the link. I know the GN is a slightly different beast but my tps was "slightly" off on it and I had the exact problem as I am experiencing now with the Ty and had no code then either. Once I got the gn with in the right adjustment numbers it ran perfect. I did see the numbers in the link that I was looking for though. It won't hurt anything to check it. I'm asking Santa for a scan tool for Christmas lol. KR is always a worry with any turbo'd vehicle.
Re: Setting TPS
The trial period for Datamaster is free. Www.ttspowersystems.com
