mildtowild
Custom Upholsterer
do the GN and TY use the same fuel regulators? in other words will a GN Specific APFR bolt up tp a ty?
Suny said:can you run a walbro with the stock harness or should ordering one be a better idea?
I'm running a 7 year old walbro 255 HP with the stock harness, 11.45 @ 117 no problems. I didn't even have to upgrade my fuse.Suny said:can you run a walbro with the stock harness or should ordering one be a better idea?
DaveP said:^^X2 and X3^^
I think having good system voltage has a LOT to do with success in this area. Low voltage causes higher amperage, with the associated burned connectors. From my observations the guys with a re-located battery, or underdrive pulleys are most susceptible to low-voltage issues.
Dave
