BlackTyphoon213
The mods I've done is a Wideband 02, 60# injectors, Vortec Heads, Comp Cams 212, AFPR. The turbo and bottom end are stock but have 5k on a fresh rebuild.
The problem I'm having is even if I cut injector pulse to the point where it kills the vehicle it's still running 11.2 AFR. I've tried three different bins and chip from Turbo Tweak all same results.
I've replaced the MAP sensor, coolant temp sensor, checked for vacuum leaks (should actually lean it out, and does when I pull one off the intake), injectors are new and flow matched. I've been having this issue for a long time gave up on it, and would like to try and get it resolved. I don't think it's the Tune because these bins and chips have worked for others. For some reason it's running extremely rich regardless of what I change in the Tune, or replace. Any information is greatly appreciated.
Thanks,
Andrew
Thanks,
Andrew
