RiceEater
Ok so my 92 TY has been running richer and richer so I stopped driving it for a few months till I could figure it out, and now this is what I have. In the last 2 weeks it has started throwing code 45 rich while driving, and starting to run like crap. This went on for about a week and now it shows code 15 for coolent temp low. I just did a DM run and it shows -37.8F as my engine temp! I removed the 160 thermo the truck came with and put in the stock 190 and replaced the temp sensor but it is still the same. The dash shows 190 but DM shows -37.8 no matter what. I checked the new sensor and it seems to ohm good but I put my leads on the connector for the sensor and got 10 ohm, now is that the problem? If I jump it like that shouldn't it be 0 with the ohms comming from the sensor? I can't follow the wire back very far to see if it is broken and it is wrapped but I just wanted to ask and see if I was in the ball park. The truck is almost all stock, I just did the IC upgrade and put a motes 2.0 in running the starter bin. I wasn't sure if it could be the bin doing this, but I loaded a few and they all do it. Any ideas would help. Thanks!
