someone else said:The connecting rods have the tinsel(sic) strength of a wet noodle.
Tensile strength doesn't seem to be the factor most important - it refers to the metal being pulled whereas the rods are designed to withstand the much larger compressive force. That's apparently when the rods let go. This article from hotrod suggests that by changing the fasteners, you can double the horsepower of an engine that the rods could handle. That will depend on torque and seems more relevant to higher RPM motors than ours but still...
http://www.hotrod.com/techarticles/general/choosing_the_right_connecting_rods/
With very few exceptions, the weakest link in a stock forged rod is the fastener system. The rod bolt is usually the most marginal component. Simply upgrading from stock bolts to quality aftermarket replacements can improve durability by 50 percent. Just be sure to have the big end re-sized to restore concentricity any time the bolts are removed. Stock forged steel rods are an economical choice that should be able to handle one horsepower per cubic inch with quality fasteners, and as much as twice the factory-rated output if the beams are polished.
Read more: http://www.hotrod.com/techarticles/general/choosing_the_right_connecting_rods/#ixzz2JpyO3Y7K
So 500hp on stock rods?
When was the last time anyone had a rod let go without there being some other major reason? Am genuinely curious where this folklore comes from.
Most of the time I read about bearing failures but everyone talks about the stock rods being weak and crappy. Yes they are weaker than forged but when was the last time someone bent a rod or similar? It obviously happens but usually there is some other major failure that a forged rod wouldn't cope with in any case.
I've only been on the forum for 7 years so maybe things went on before but I am curious to know why this belief persists.
Why do people rate the stock rods so poorly?
:2cents:
