dustinwinkle
1993 #0036 White/White
I just rebuilt the engine in my ty and am having some problems with oil flow. I have the stock remote oil filter setup.
The engine is building so much pressure it is blowing the gasket off of the oil filter. The oil pressure gauge will peg out. It would seem the I have a blockage somewhere. I disconnected the oil lines at the filter. I have no problem with flow through the cooler. I cranked the engine over with the line disconnected and oil is getting pumped to the filter fine.
My thought would be that the return (out) line to the engine is blocked. I tried to force air through it and it blew oil out through the (in) line from the engine. This does not make sense to me.
Does anyone have any suggestions? Does someone have a schematic that shows how the oil flows through the engine? There was a gasket I installed where the remote lines attach to the block, is it possible I installed it incorrectly?
Thanks to any help in advance!!
Dustin Winkle
93 Ty #0036
Dustin Winkle
93 Ty #0036
