I work at a local garage and we happen to be doing a 2000 blazer with a rear end that was blown up.So I took it all apart and noticed it had rear disc brakes,then i thought more in depth.Rear brackets,calipers,and mounts and all the lines are extra off the old rearend ,so I saved them.Now the question I have is how does the abs on a 2000 differ from the abs on the wifes 92 typhoon.Cause the housing and all mounting is the same.What else do i need to keep the abs working on the TY? Also parking brake where does that change.....etc
