Falco
Howdy,
I've started to install my rear Baer kit (BTW, Mike@Rockville Speed really rocks :tup: ).
One of the first steps to remove the pinion shaft from the rear differential in order to be able to remove the axels. I've removed the little bolt, which supposed to keep the pinion shaft in place, but the shaft still doesn't want to go out. It has a little play (around 1mm), but that's all. I've even tried to tap both end of the shaft, but it didn't help. Am I missing something here? What should I do to get that shaft out?
Thanks in advance,
Thanks in advance,
