List,
After spending some good quality time with my truck over the past few weeks I finally got most of the bugs worked out and it is running strong. However, I seem to be having a problem with my wastegate. It’s a Turbonetics Deltagate mounted on the crossover tube. Before I installed the new engine the wastegate would hold a solid 10psi base pressure. Now it spikes to 15psi and doesn't seem like it wants to stop. I took a peak at it today and the valve doesn't seem to be stuck. I was able to pry it open with screwdriver.
I know there are a hundred things that could be causing the problem, but I'm out of ideas. Anyone got any suggestions? How can I test the wastegate on the bench? Vacuum pump? Air compressor? What should I be looking for? It’s a pretty simple principal so I'm not sure why it isn't working.
Thanks,
Thanks,
