Pro-gram splayed cap torques specs
Falco
Howdy,
I'm looking for the torque specs for the splayed Pro-gram man caps. So far I found the following procedure:
*hand tight for the studs
*30 ft/lbs for the center nuts
*30 ft/lbs for the outer bolts
*70 ft/lbs for the center nuts
*65 ft/lbs for the outer bolts
These with unsing moly assembly lube. What do you think? What kinda procedures are you using?
Thanks in advance,
Falco
Re: Pro-gram splayed cap torques specs
Bump. Noone ever had to deal with splayed caps!? I don't think so... Pls share your experience.
Thanks,
