spooldup
Super Member
I just installed some arp rocker studs that were special order and are longer than the normal arp studs we use on the vortec conversions. I then put crane 1.6 gold rockers on and screwed all of the poly locks on. I then rotated the motor until the exhaust valve just started to work and attempted to adjust the intake valve. I began to tighten the lock until the pushrod could no longer be spun by hand. The problem i am having is the poly lock at that point is all the way down and the hex head on the lock is touching the rocker itself. Do i just need a taller set of poly locks or did i do something incorrecly here?
