ghettosled
SYTY SUPERSTORE
Jordan. Try this. Run a vacuum line to the side of the WG and plug the top vacuum port on the wastegate. Take it out and see what happens. I bet it will overboost. If it does, then you know your problem is that the controller is venting pressure. If it only makes 15psi with the top port closed, then your turbo is bad or your manifold/intercooler is leaking. Let me know what happens.
