PCV Valve(s?)
BadForm
Okay... doing some minor work, and trying to hunt down the cause of some oil in the intake. Doing a net search, I keep seeing reference to the SyTy having PCV valves. Is there more than one? Where are they located? I think one is under the IC in the valve cover. Where/s the other?
Thanks!
TechWeasel
Just two, eh? Then what goes in the hole on the driver's side? I honestly don't know, since mine had a little K&N breather in there (and no airbox) when I got it?
Is it another 799C PCV valve, that's normally plumbed into the airbox?
Zac
No PCV on the Drivers's side. Just a tube going staight into the airbox.
ZAC
SyTyJedi
Jedi Council
The drivers side is for clean, filtered air to enter the crankcase. It will draw air in as needed when it is sucked out by the passenger side valve operations.
TechWeasel
Interesting... this may be the source of some of my problems, then. I'll try stuffing that K&N back in there and see if it helps.
Thanks!
