From what I understand the output shaft is syty specific. I'm rebuilding one out of a 92 typhoon at the moment and the rear planet has melted down due to low trans fluid. The output shaft looks like it has been hot and I think it is best to replace it. I've got an output shaft from from a standard 4x4 that I can swap in. Has anyone done this before? Any down sides? They are dimensionally the same but there are some marked differences. The syty unit has 2 grooves near the output end of the shaft. The oil holes are also in different locations.
Thanks,
Brian
Thanks,
Brian
