Re: Od tcc ?
I see that you did a turbo upgrade. I am in the process of lookng at turbos, what did you need to do when you upgraded your turbo? New DP or ? Just curious!
DP, or mod the one you have.
Mine does the same. I attribute it to the stall speed of the convertor. What stall are you running?
Im not sure what stall the conv is, trans was rebuilt before i bought it and all i have is a receipt from a shop in NY, called them and they said they are sure it would have gotten the right conv, when it was replaced.
parts replaced on rebuild reciept are, 1 new assmbly set-LS 1 new filter, 1 new band-brake, 12 qt fluid dex III, 1 exchanged rebuilt torque conv, 1 sprag assy,
rebuild was done 11/21/06, with 107748 miles. I bought it about a year ago with a little over 108,000 it now has 108,500
the truck wasnt really in driving condition when i got it so i doubt it could have been abused too bad between rebuild and now due to brakes and front suspension and bad fuel pump. But that is NOT a fact.
My Sy has a RR built tranny with a 2800 stall, so driving this stock truck feels weird anyway.
