skwayb
NWSTP
Re: No boost at all!!!!
Check the vaccum line to your MAP sensor. I had the same exact problem when the line blew off my MAP sensor. Would build boost until 0 and then go flat on its face. The map sensor could also be bad. Check to see if you are seeing anything in datamaster. If you are using tunerpro, see if the ecm sees any voltage from the map sensor.
